I am using OpenBridge Modeler CONNECT Version 10.07.00.50 to make a test model of a bridge that we are currently working on. It's mostly a proof of concept but I am running into a few issues while modeling.
The primary issue being that with the relatively high skew our substructures have (40 degrees from normal to the alignment), the program appears to keep clipping the end of the deck that I generate, which causes the exterior girder of the bridge to not be placed when assigning the beams into the beam group. It only does this at the start support, the end support is fine. See below:
I am not sure if I am missing a Variable Constraint or am hitting some limit of the Deck Template I have chosen, but not matter what I seem to edit, it does not improve this problem.
Let me know if this is a known bug or if someone has experienced this problem before. I have also attached the file below.
Thanks!
Spruce Mountain Road.DGN
Make the Support Line longer ... it must be long enough that it covers the full width of the deck and cap and any other bridge elements present. They can't be too long...but can be too short.
Before:
After:
Answer Verified By: Alexander Abbott
Great, thank you. I knew I was missing something.
