I am getting the following error after running LARS model analysis
"Insufficient section information for getting check points distances information for current member. Check reports for errors."
and
"Insufficient section information for plotting the moment diagrams for current member. Check reports for errors."
When I check the report, it says
"G01 0.000 Range sequence number out of order. Data editing may have caused a Data Type 11 to be purged. (May be a problem for program maintenance.) (FF)"
Is there an easier way to resolve this error?
I have lots of defects in the members so it will be time consuming to model it again.
Instead of a defect or a hole I would suggest you to reduce the size of the flange or web based on the equivalent size of the defect or hole.
reducing the size of the flange or web based gives better results in the output.
