老师 在RM出现这个错误,请问应该怎么调整?
Hi Fog,
Initially realize this is not an Error, is just a Warning.
It states that the Load Type G is not implemented for the Springs.
You could get rid of it by unselecting the Spring Elements Series from this load cases.
Marcos Beier
Senior Technical Support Engineer
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 14 hours ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
好的 谢谢,请问在哪里可以了解到添加梁截面信息的教程呢?我尝试修改过都没成功
Dear Fog,
You can find complete examples and documentation included in the software installation at File/Examples.
Also find tutorials on adding beam section information at the instructions documents by selecting the button Description. At Training Examples\04a Balance Cantilever there is a section Modifications in Modeler and all the Temperature definitions are added to the CS.
At the Top Menu click on Modeler / Cross Section to modify directly the Cross Sections drawings. Geometrical modifications could be made either in Modeler, Analyzer or externally at OBM or in a .tcl programmable ASCII text file.
Best regards,
thanks
