hello Everybody!
At this time! Can you help me?
How to draw " this member " of Arch Bridge in Rm-Bridge?
Note: only is red lines in the picture.
Hi Due,
To detail this project I would suggest you to create one additional Axis definitions for each of the transversal truss elements as simple Cross Member and Link as transversal are not enough to detail your elements members.
So far it's the only way to allow you to apply the Active/Inactive rules necessary to define the created Links inside the Cross Section.
In this new Cross-Section add Part1 and Part2 as Top & Bottom and the diagonals TopToBottom and BottomToTop with Create Links: .
For the diagonals modify the input in Step as 1 (default is 0) and your final model should be like the one below.
Use as reference the dataset and documentation you can find at File\Examples\Verification Examples and FAQ\ Modeler Link Segments & Truss Modeling as shown below:
Best regards,
Marcos Beier
Senior Technical Support Engineer
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 1 day ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
Answer Verified By: Due Due
thank you so much for your answer. let me do it.
