I can not load my Explorer dialog box or my Properties dialog box. When I try I get the following error message:
Loader: Could not load application C:\Users\brownj2\AppData\Local\Temp\Bentley\OpenBridgeModeler\10.0.0_1\AddInLoader1.0\Bentley.ECUISupport.ma
Any help would be appreciated!
We've not seen this error Jeremy. We need more information to troubleshoot. Please file a service ticket (connect.bentley.com). Please provide details such as OBD/OBM version #, Operating System, any other Bentley software installed etc.
Jeremy, since it's in a temp folder, that leads me to believe something might be stuck or not regenerating. Try deleting that folder or moving its contents and then go back into the program. Jeff Oestreich, keep an eye out if you see this.
That took care of it. I moved the files, and then went back into the program like you suggested and all was good. Thank you very much!
