Kindly anyone provide the solution to export staad file into RM bridge advance model
Hi Pardeep,
Based at the STAAD file you could edit a text ASCII file in the .tcl format as it is a scripting interface that you can import into RM Bridge.
You can find more information about it at Help/Technical Notes/TCL...
Marcos Beier
Senior Technical Support Engineer
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 2 months ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
I tried a lot to convert the with staad file into tcl file. But could not do it. I herewithLL-2CLA-70R-BOWSTRING.std attached the, kindly help me to convert into tcl file.
