Has anyone else encountered LEAP Bridge Concrete 19 crashing when clicking the "Help" icon and then searching for a keyword?
The workaround solution for this issue is to go to C:\Program Files\Bentley\LEAP Bridge Concrete CE V19\Help\US folder
then check the PDf files or .chm files of different modules of Leap Bridge concrete.
What do you mean by "check the PDF files or .chm files"? I just checked mine...they all match what you have shown here, they all open without issue, yet LEAP Bridge Concrete still freezes in the Help menu and wipes my file clean every time...
Since you were unable to open the Help menu ,I gave you a workaround solution to open the help files.
I would also suggest you to download the latest version V19.01.00.11 from Bentley select server.
I just checked mine...they all match what you have shown here, they all open without issue, yet LEAP Bridge Concrete still freezes in the Help menu and wipes my file nox Kodi Lucky Patcherclean every time...
