Why is Conspan using the live moment distribution factors for live shear?
LLDF for Moment Shear are assigned or calculated and applied separately.
Check if the DF's are assigned same for both Moment and shear.
If not this might be a unique case. Would suggest you for download the latest version
19.01.00.11
from Bentley select server.
If you are still facing this issue then please email me the file and the version number so that I can test this issue.
What is your email?
vinay.mysore@Bentley.com
