Hi
I have modeled multi column pier with ABC modelling and when i am analyzing Pier, it is not performing analysis and giving error Frame is unstable. Please help me and if you guys have time to check.
Thank you
Vivek Kushwah
+91-7974638191
https://drive.google.com/open?id=1eT5ghA90hLplOfNRPEnWYRs9aPYj8vdM
I ran the attached file in the current release version and I did not get any error message.
The program is showing more realistic results as shown in the attached screenshot.
I would suggest you to install the latest version from Bentley select server and that should resolve your issue.
In V19.00.00.22 there was an issue with the program showing error message and this issue has been fixed in the current release version.
Hi Vinay
Thanks a lot for the help, it really helped. I have raised request to my IT department as well it will take few days. till then can you please give me the Auto design result of Pier cap only meanwhile i wanted to check the final moments.
Please email me to this email Vinay.Mysore@Bentley.com
can you please tell me how can we apply weight of median slab at mid span beams as composite load.?? As when there is no option for distributing the composite precast load at mid span beams.
