Occasionally when I print beam design results, I will get zero camber and deflection values reported in the design summary. I have to go back and rerun the analysis and that clears it up. Is this bug documented and is there a fix?
Having the same problem with version 20.00.00.53. If the analysis is rerun problem corrects itself.
