I'm trying to make a staged bridge and am currently creating two different bridges in one file. I recently saw the build order option. What is this doing? Is there a way to do a staged construction presentation using this?
Thanks!
Please let me know which program you are working on as it will help us to provide a solution.
The Build Order field is an optional input that assigns a linear pattern of assembly as an ordinal integer to each object component in this group to specify a construction sequence for super and infrastructure elements. Users can type an integer in the Build Order group and the Build Order number is incremented automatically from the highest previously placed build order number for the bridge. The data is used for stage analysis and construction simulations. More information can be found in the manuals at the link below:
Place Cantilever Segmental tool (bentley.com)
Marcos Beier
Senior Technical Support Engineer
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 4 days ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
