Dear All
I am designing a one span cored slab bridge using LEAP Bridge Concrete Connect Version 19.01.00.11 and LRFD 8
The "Cap" design output for "Cracking" (AASHTO 5.6.7) shows a code violation when checking top and bottom bar spacing at a given point. Also, when I put all numbers in the equation above, I don't get the provided spacing, fss = 0.06 ksi, h = 36 in, dc = 2.56 in, gama = 1. Please see the tables below. The reference should be 5.6.7-1 not as shown in the table.
Is this a "program error" or am I inputting something wrong?
At top, the spacing check passed
At bottom, the spacing check failed.
In detailed Design results report the Article number should be changed.
Its a error in the program.
Thank you for bringing this issue to our notice.
Thanks much
What about the fss? Why it is always 0 at the bottom?
The top face is in tension and the bottom face is in compression.AASHTO 5.6.7 says that equation 5.6.7-1 checks the spacing of the mild reinforcement in the layer closest to the tension face
At the bottom face since there is no moment which creates Tension or Tensile stress the program is eventuallyshowing Fss=0 ksi and the equation 5.6.7-1 does not apply there and as a result of which the program is showing Srqd as 5” .
I hope it helps
Thanks much. Solved.
