Hello All
I have a rectangular beam with circular voids, it has 24 strands distributed as shown below and 2 #4 rebar at the top (shown in the right picture only). When I added the rebar at the top, they were located as shown in the right picture. Is there any way to move them across the width of the section?
Currently there is no option to move the rebar across the width of the section.
Thanks much, we hope seeing that in the future.
I believe my question is similar to the one above.
I would like to specify the horizontal spacing between longitudinal rebars in an inverted T bent cap modeled in LEAP Bridge Concrete CONNECT. Is it possible to define the rebar location/spacing horizontally?
If it is not possible now, I hope this function is being developed - it would allow designers to space bars correctly on inverted T cap ledges and around precast bent cap grout pockets.
Thanks Cage Cluff, we hope seeing that in the near future
