Hello the green + symbol button does not seem to be working in the OBM Beam Connection Plate Library dialog. I check and I have access to the XML and can edit in that file. When I click the button noting happens. No messages, the button highlights but that is it. The stiffeners library seems to work fine. Any ideas on this?
I am unable to reproduce the issue. When I click on the green + symbol I get the "Connection Plate_5" as shown in the image. Is this a machine specific issue or happening? What version of OBM are you using?
