Hi. I want to ask something. I use the OBM Update 8 version and my friend use the older version. But when my friend try to open my dgn file. The OBM said that to view the file is ReadOnly. Is this possible for my friend to open and edit newer version of OBM file? Is there something that I or my friend have to do? Thankyou.
You will not be able to open a file created with the last version of OBM in older versions of OBM because of the schema changes between versions. You can still open that file in Microstation but you will not have the intelligence of the OBM object, thus, OBM object will be seen as Microstation simple solids.
Answer Verified By: Riyan Febriyansyah
