OBM column/pile elements greater than 500m
Hi, I'm modelling a conceptual bridge which will be standing on floating pontoons tethered to the sea bed. The tethers I created using a pier template, utilising a steel column as my tether. This is elevation constrained to the pontoon and the terrain dtm file. I notice however that because the depth is greater than 500m the column won't create, just the cap and footing. Is there a configuration I can change so the threshold is greater than 500m?
Kind regards,
Matt
