New user here, playing with different tools in OpenBridge Modeler 2019 Release 3. This should be a straight forward question - should the ProConcrete slab reinforcing detailing tool be able to add reinforcing to a bridge deck? It looks to be set up for standard reinforcing, but the tool never seems to add any reinforcing to the deck in any models or samples in the way that the column and footing detailing tools do, for example. Am I doing something wrong - any advice is appreciated!
The wall/slab tools are there to help you reinforce Microstation solids or ProConcrete solids. For OBM decks use the tools from the red rectangle bellow.
