I came across these issues while trying to export models from OBM to LBC and LBS.
1- When I send a skewed prestressed concrete bridge with the back of abutment as reference line to LBC, the transferred model will end up having flared beams and wrong beam lengths. Is there a reason for that?
2- If I have a multi-unit bridge made of steel I-girder, it seems that I can only send one unit at a time to LBS. Is there a way to send all the units at the same time? What would be the workflow to design piers that are connecting those units?
Would sending the model to RM Bridge would solve these issues?
Thank you
