I am trying to Add a bridge to an alignment but the alignment says "No Active Profile" when I try to click on it. My road designer made an alignment and linked the profile. Am I having a compatibility issue? I have OpenBridge Modeler version 10.06.00.41 and the alignments were made in MicroStation SS4 8.11.09.838 & InRoads SS4 8.11.09.903
Most likely you did not assign the profile as the active profile for the selected alignment.
If assigning the active profile does not work for you, please send me the file at vlad.grigoras@bentley.com and I will have a look at it.
Answer Verified By: Andrew Pavy
I have had the same issue and for me it was compatabiility issue. I had created the alignment using geopak (v8i series 10) but openbridge version is the Connect edition (10.04.00.747).
Once I created the alignment using ORD (CE). Problem was solved.
not sure how your comment will help the issue.
I am also experiencing this same issue, but I'm running the latest version of both OpenRoads Designer (10.8.1.33) and OpenBridge Designer (10.8.2.10). I know the alignment in ORD has an active profile (set by constant elevation), but when referenced into OBM it tells me there is "No Active Profile". How do I remedy this? Any help would be very appreciated. Also my data is hosted in ProjectWise (10.00.03.167).
