I am trying to Add a bridge to an alignment but the alignment says "No Active Profile" when I try to click on it. My road designer made an alignment and linked the profile. Am I having a compatibility issue? I have OpenBridge Modeler version 10.06.00.41 and the alignments were made in MicroStation SS4 8.11.09.838 & InRoads SS4 8.11.09.903
Eric ... an alignment can have one or more profiles. Unless one is set to be 'active' , no profiles are active. Make sure the designer using ORD not only set a profile but made it active as well. You probably do not want the requires road alignment toggle nor the use road alignment stationing toggle enabled either.
Steve. My ORD profile is set active, as you can see from the image below. I would like the bridge to use the ORD alignment and station.
I beleive the alignment and profile need to have a name as well.
Verify that the Profile set as Active is defined for the selected Alignment and stationing and not somewhere else
Marcos Beier
Senior Technical Support Engineer
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 2 months ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
Hi Eric,
Please send me your working file to me to have a look at it.
vlad.grigoras@bentley.com
