Has anyone see this error message when opening OBM?
I received this after i upgraded to version 10.08.00.60
-Wayne
Wayne… Are you using your own workspace or the delivered workspace? This should work fine with the delivered workspaces.
You are using an old configuration that is not updated to reflect the last updates done for the integration of ProConcrete inside OBM. Please be sure to read the information provided in the documents OBM - Workspace Updates - _______.pdf found in C:\ProgramData\Bentley\OpenBridge Modeler CONNECT Edition\Configuration\Organization-Civil.
Answer Verified By: MarcosBeier
