LEAP RC-PIER P-delta effect in load combinations
When checking Show P-delta Effects in the Analysis tab, are the values shown represent values with p-delta effect? For example, are the column/shaft moments magnified with p-delta factor in these load combinations (with a "C" on the end of the LC#)? If yes, they should match the values in the Column tab Design Statuses, right? If not, what values are these?
If none of the above correct, can you suggest how to extract p-delta factors for each column. I'm trying to extract P-delta factors at my top of shafts, but I'm getting 3 different values per shaft for my Mx and Mz for one Load Combination that's showed as the one causing the worst loading.
Edit: Quick investigation into the load combinations with the "C" showed that the LC# shown on the Column Design Statuses is wrong. I was able to find the values under a different Load Combination number. Is this a known glitch?
  • This is a general example to explain :
    if the user is getting the letter “C” under combination for footing design.
    C generally represents P delta analysis or Magnified moment analysis .
    Once the P delta analysis is selected and the column is designed you should be able to see the
    Vertical load and moment at the bottom of the column in the Design status page
    In this particular case 36C is the critical Load combination and the moment is 7121 k-ft.
    When the footing is designed under flexure user can see the same moment which is 7121 k-ft and the combination as C in the Z direction.
    Please let me know if this is the information you are looking for.
  • Yes, thank you for your response. I found this question
    Document Information Document Type: FAQ Product(s): LEAP RCPIER/ Substructure Version(s): All Original Author: Bentley Technical Support Group - VM QUESTION: When the P-delta option is checked…
    and the answer confused me, so I decided to verify. I know this is an old post. RCPier had numerous updates since.
    Below are screen shots of the design status of a drilled shaft (it's a single drilled shaft supporting a column), the load combination that should have been showing the same loads as in the design status (but it's not) and the actual load combination that has those loads. So my impression is that the load combination number shown on the design status is not correct. I think this is a glitch, I'm using version 19.02.00.33 of LEAP Bridge Concrete. What I'm worried about is that in the design status of the shaft, it's not the load combination number that's wrong but the loads. Resultant moment and the axial load in the actual load combination 9341C is higher than 12047C. Please let me know what you think. Thanks.
  • Please email me the file to vinay.mysore@Bentley.com so that I can test it and if it is a glitch I shall report it to the development team.
