I am using OpenBridge Designer CE (10.04.00.747) and ProjectWise Explorer V8i (SS4) (08.11.11.590) and am having trouble getting OpenBridge to see ProjectWise. I did look for the configuration file PW.cfg and and the "PW_DISABLE_INTEGRATION_FROM_DESKTOP=1" is commented out.
I am just having no luck getting OpenBridge to see projectwise. Does anyone have any ideas on what else I can check?
I would check for ProjectWise compatibility issues.
ProjectWise V8i was released well before OpenBridge Modeler CONNECT
Check these locations for ProjectWise Compatibility:
https://docs.bentley.com/LiveContent/web/ProjectWise%20Version%20Support%20Matrix-v1/en/GUID-1A2E193F-C3D9-4709-92A2-E5B9301B5946.html
https://app.powerbi.com/view?r=eyJrIjoiOTViOTExNTYtOWUwNS00ZWNmLTliMjYtYzU0OWY5ZmZhYmM0IiwidCI6IjA2N2U5NjMyLWVhNGMtNGVkOS05ZTZkLWUyOTQ5NTZlMjg0YiIsImMiOjF9
Answer Verified By: Dennis Wadas
Thank you so much for your response David. I'll get a connect version of ProjectWise and give it a try. Have a great weekend!
That 100% worked! Thanks again David!
