Has anyone encountered this error:
Under Home>>SupportLIne>Place Multi to place lines that represent the locations of the piers and abutments, I receive an error "No Active Bridge is selected". I've tried selecting the bridge but so far, nothing is working.
I'm trying to learn the software but am stuck.
the file is the Precast Bridge.dgn drawing.
Lynzie:
Please check your Explorer window and see if you have "added" a bridge to the file prior to using the SupportLines tool. If you do not see a bridge listed, use the add bridge command again, select the Route97 alignment, then data point off the alignment to "add the bridge".
Steve,
Thank you. It works. And thank you for including the steps to adding the bridge.
Lynzie
Yes it worked indeed. Thank you so much sir Upsers.com
