how can i change bearing dimensions at bridge parametric layout?
and how can i change the bearing distance at bearing/beam seats tab?
Service request has been created and solution has been provided.
Can you share the solution? Once I use ABC wizard to set bearing distances on the abutment, I can't modify the bearing locations. This is necessary as design changes slightly throughout the design process. The "OK" button is blocked out when I try to modify anything.
i would suggest you save the substructure file separately with a different name and then modify the bearing distances.
Or create a separate substructure file and then design the Pier.
Once the ABC wizard bridge is modeled, updated and save the program will not allow the users to modifty the bearing distances.
Please check some of the topics related to substructure modeling in RCpier.
https://communities.bentley.com/products/bridge_design___engineering/w/bridge_design_and_engineering__wiki/55093/how-to-create-a-standalone-substructure-or-superstructure-only-model-in-obd
