After using Connection Client to upgrade to the latest version of OpenBridge Designer, upon completion I do not have the program OpenBridge Modeler. The Leap products are there but no OpenBridge Modeler. Has this happened to anyone else? During the install I can see that it downloads OpenBridge Modeler and installs it. The last thing it does is uninstall previous versions of OpenBridge Modeler. I wonder it its removing the newest installed version? Can anyone tell me what I may be doing wrong? Any help would be greatly appreciated.
Hi Dennis,
It may encounter a problem when doing the upgrade due to server/internet issues or a local issue with your configuration. Go to Control Panel and uninstall manually this version. Please BACKUP your configuration data. Then download the on-demand installer and manually install the new version from the link below.
https://softwaredownloads.bentley.com/en/ProductDetails/2714
Be sure to read this post, before upgrading or working with the new file format!!
https://communities.bentley.com/products/bridge_design___engineering/w/bridge_design_and_engineering__wiki/48343/openbridge-designer---new-file-format-obdx-in-v10-08-01
