I am trying to model a steel box girder bridge in OpenBridge Modeler. In the Built-Up steel section, I do not see how I can have two inclined webs and two top flanges...
How are the steel boxes modeled? Thank you
Hello Nicolas, We are currently working on adding this functionality in OpenBridge Modeler. It will be available in our release coming up in couple of months in August.
Thanks,Sri
If separation of box plates is not required, work around is to define new beam section template with void.
thank you, is this now available? i still only see the steel plate girder not steel boxes.
Sorry Nicolas, It is taking longer than expected due to the geometric complexity. While we are making good progress... it is not ready at this time.
