I created my model using the ABC wizard. Since this point, I have had to adjust the size of my pier cap, and now the bearing locations are off. I have attempted to adjust the locations using the Edit Bearing//Steps option but it is completely greyed out.
Do we have an alternate way to adjust these bearing locations without using bridge parametric layout?
Sincerely,
AY John York
currently there is no option to move the bearings once the model is fixed and updated.
If you are planning make some major changes like changing the size of pier cap then I would suggest you to recreate the model from scratch.
