I am using the LEAP Concrete module within OpenBridge Modeler. One issue I am noticing is my prestressing strand patterns are not loading/copying correctly. If I create a custom strand pattern for a girder and then copy to all girders, the other girders generate a strand pattern which is not the same as mine and not what I desire. I have also tried saving my custom pattern and then uploading that pattern in the other girders. However, this still results in a LEAP generated strand pattern instead of my designed one. My workaround has been to manually change each girders strand pattern to match my own, but I feel that there should be a better fix. Does anyone know why this might be or a solution?
Jack
Please email me the file to vinay.mysore@bentley.com so that I can test this issue on my machine.
Did you ever get a solution to this? I am having the same problem as well. The girder that I define keep the strand pattern I set, but the others I copied change patterns after I run analysis.
you can try this method once you have copied all the strands and before saving the file.
https://communities.bentley.com/products/bridge_design___engineering/w/bridge_design_and_engineering__wiki/16043/options-not-getting-retained-in-the-beam-s-tab-design-parameters
