I am new to LEAP Steel (and 3D modeling in general) and am trying to analyze a single span curved steel plate girder bridge built on a 214' radius. The span length along the centerline of the alignment is 80'. The cross section will consist of 4 plate girders with 27" webs. Due to the shallow nature of the girders I will need to use diaphragms (channel or w-shape) in lieu of cross frames. When i run LEAP Steel in grillage mode, it runs fine with no problem. When i switch to finite element mode the structure becomes unstable. I then switched the diaphragms to K-frames (did not change anything else) and it becomes stable with a finite element analysis. Does anyone know why this may be? When I move the bridge to a tangent section of roadway it also runs without any instabilities.
Thanks for the help,
Anthony
Diaphragms are pinned elements at both ends and do not offer lateral support.
Answer Verified By: MarcosBeier
