Hello
How can I modify the bearing layout in leap bridge concrete as the interior bent length is different than the exterior one?
Dear Michael
This link takes me to the CSI bridge example. Are you sure that this is the answer of changing the layout of bearing in leap bridge concrete?
Rafal,
Please use ABC Wizard for bridge definition and, advanced definition of girders (bearings)(see screen shot below).
In a 3D model (integrated model), you are not allowed to modify bearing position under Substructure; you can corrupt the model is you try this.
Thanks much
