I have been experiencing a substantial amount of instability/crashing in LBC 20.00.00.46. The program will randomly freeze and become unresponsive. This happens when I run an analysis, look things up in the help manual, attempt to save, and many other random times. After running an analysis if I let the program sit for a minute or two it won't freeze, but if I proceed to use the program right after an analysis is completed, the program will freeze. The program will also randomly delete the substructure analysis for no good reason. This has happened when I run the design status for the columns or cap, saving the file, and other random times. If I save my file from the substructure, the model will not be updated and the changes I have made are not saved.
Sincerely,
AY John York III
I have been getting freezing/crashing as well. Happens at different times but most consistent one for me has been when i am modifying bearing loads.
OpenBridge Modeler - 10.10.00.85Microstation - 10.16.02.34
Comprehensive 3 Day OpenBridge Modeler Training
I am having similar issue with my Program LEAP CE V 20.0 , especially when I use cross combinations for my Load combination parameters. Have you found a resolution for this ?
Also what is the processor power needed for LEAP CEV20 to run analysis without crashing ?
