I am trying the model the Tunnel and slab inside the tunnel. Facing the problem, how to correctly model in RM bridge. Kindly help me. I herewith attached the RM and GP file along with the crosssection of the Tunnel for your reference. While making the elements, the joint crossing the straight and circular construction line not able to select.
Answer by SR 7001121281, slab in Tunnel modeling.
Ana Carla Peres
Senior Technical Support Engineer
Bentley BrIM
Answer Verified By: MarcosBeier
