I am trying to start a new project and need to organize seed files for design models before creating files. We are using multiple Bentley products eg. Microstation CE, OpenRoads, OpenBuildings, OpenBridge Modeler, etc. From My understanding, all the standards should come from configuration and the seed file will be a blank platform to start design which will have a basic setup like working units, views, model names, etc. (which I am not too concern). The only thing I am trying to understand is, seed file for OBM and OBD and all the other software mentioned before have .dgn file. So, What is the difference between those seed file, can I exchange the seed file across different software? If yes, would I miss something? Is seed file designed to work with a particular software package?
For example,
In order to use OpenBridge functions properly, do I need to use the seed file provided with the install? Can I use an existing seed file that I use with Microstation for 3D modeling if units and all other settings are the same?
Jaimin Patel
Well, the civil products (OBM and ORD) are in sync because they use the same framework and they are specialized products. MS is a general product that can do everything so, there are differences between them. In OBM and ORD we use survey foot because of the site requirements.
Ideally you will want a workspace that everyone is using regardless of product. Many have chosen to use OpenBridge for everyone in the structures department as it has all of the MicroStation tools in lieu of having to install a variety of products and configurations.
