I am new to LEAP Steel and was wondering if it has the ability to perform LFR (load factor rating) as opposed to the modern LRFR rating. I am not seeing any options within the program to change this and I have not seen any old posts out there explaining this. If the program is able to where would the option be located?
It'd be really nice to see that added. NYSDOT requires LFD Load ratings on all projects so until LEAP Steel can do an LFD load rating we really can't adopt it as our main steel design program.
I totally understand your requirements
I would suggest you to raise a enhancement request in our ideas portal.Please add your idea for something that you believe would make OpenBridge and OpenTunnel better.
Please click on the below mentioned link to access the IDEAS portal
https://communities.bentley.com/products/bridge_design___engineering/i/lars-leap-openbridge-opentunnel-rm-ideas
Please file a suggestion in the Ideas Portal so that it can be considered for future enhancement:
I do believe I have done that already.
In that case the product development team will look into the enhancements based on Priority and will add the feature.
We do load ratings for quite a few states and they all require LFR ratings unless they were originally designed with LRFR. And then they require both. So adding LFR rating capability would be a big improvement for the rating section of this program.
