I am running into an issue when I go to place a Civil Label.
It seems to add an extra in-line leader to the cell that is used. is there a way to turn this off? I know it uses a dimension style to add the leader type. My dimension style has in-line leaders turned on, but it seems that this place civil label tool adds a second one (see the top label in the attached photo with the leader highlighted in magenta. Note that there's already an in-line attachment on the leader, which is driven by the dimension style.)
When placing without a leader, it still adds an in-line leader or node of some kind (see the middle label in the attached picture. The arrow is added to the original cell just to show that it is loaded in the "Place Civil Label" tool)
I need it to look like the original cell (bottom label in the attached picture)
any tips on making this work?
What software are you using? if it is one of the Civil packages, you may want to Move this post to the OpenRoads Forum
MaryB
Thanks, I'll move it to the OpenBridge Modeler forum
Expressions are stored in the Settings tree, within the Label Styles folders (see Figure 1). They are not available for label style types that do not have relevant properties, such as Note label styles. But for the most part, they are available in every type of label such as surface, alignment, profile, and so on.
Thanks for sharing..
I just want to ask you that Automatically label all lines, curves, and spirals in the alignment with Line, Curve, and Spiral label styles. Labels are placed on each line, curve, and spiral entity in the selected alignment. Dinar Recaps Blog
