I am very "green" to the OBD and LEAP software. What are some recommendations for modelling a bridge that only has a portion of a horizontal curve on the structure? I'd like to keep the edges of the deck straight.
in OBD, there are two workflows, the BIM workflow and Standalone workflow.
In the BIM workflow, all geometric changes need to occur within OBM. In the Standalone workflow, you can make changes to geometry in the analytical products as well as in the modeler.
I have been trying some different things with building my model. It is the same model from my original post, but I will include some screenshots below and my Roadway folks changed the alignment on me. In the OBM model the right barrier seems to sit where I placed it. When I transfer to LEAP Steel, it seems to move and follow the roadway alignment. Is there a fix for this?
You should go to https://connect.bentley.com/ and create a service request. Attach your files to the request so the support folks can best assist you.
