Hi there,
It looks like the steel beam template library is missing. Could you please show me how I can reestablish the steel template library like AISC rolled shape? Am I missing any file at my templates directory?
Thank you,
I have exactly the same problem. Anyone got a suggestion? This is quiet a common issue .
FaceTime PC
Can you please check if you have on your machine the SPC server installed on the bellow location? If it is not installed, please reinstall OBM and choose to install this server also. All catalog steel sections are coming from this server.
C:\Program Files (x86)\Bentley\Engineering\SPC Server v8i SS4
Vlad,
I do have the directory at the same location...
any other thoughts?
Can you confirm if you can start the application from here?
Thanks Vlad.
you might be on something here. I can't find this tool at all
Do I need to reinstall the full OBM or is there another alternative?
