I am modelling bridges with a barrier of type "BN4" (Normal barrier French type 4).
I can not find a similar template in the "Standard Templates".
Can I find somewhere (template libraries) the *.xml file for this barrier "BN4" ?
If not, il there an example (Benley Support) of how to create a template of barriers with :
Supports with a certain elevation & cross-section (1 @ 2.5 m for example) + Continuous handrails with cross sections ?
Thanks.
If a barrier does not exist in the library you will need to create one. Please access LEARN Server for "Introduction to OpenBridge Designer/OpenBridge Modeler" using below link. Module 7 covers
https://learn.bentley.com/app/Public/ViewLearningPathWithMasterCourseExpanded?lpId=112428&mcId=102978
