Can anybody please tell me how to investigate Whether the External tendon Profile is interrupted by each other?
- in the picture above I try to set tendon profile across each other, But no any "Warning" or "Error" showing after I run my model
You can export the model to the .DGN file where you run the Clash detection tool in the Analyze tab of the Drawing workflow. There you can establish Criteria and Rules to get the Results you want. It is the same principle applied to Rebar but to Tendons.
Marcos Beier
Senior Technical Support Engineer
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 5 days ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
