Need a UK Workspace that complies with British Standards and Highways England DMRB. Also need to be able to combine it with an ORD managed Workspace.
Hi Chris,
There is no specific workspace that follows UK regulations.
You can still make a copy of the default Metric workspace shipped with OBM and change it according to your needs. You can create the templates that you need and save them under your custom workspace. As a note, with the next release of OBM (Update 9) you can load 2 different country codes for steel girders (UK+EU).
By default, OBM workspace is blended with ORD workspace so you should not encounter any problems when blending your OBM custom workspace with ORD workspace.
Answer Verified By: MarcosBeier
