Leap Bridge Steel - Analysis Reports for Load Combinations
Is there a way within LEAP Bridge Steel to report analysis results for load combinations (Strength I, Service II, DC only results, etc.)?   I have found where results are broken up into their service components under analysis reports, but I can't find a way to report similar tables for combined loads.  The only way to get the combinations I'm looking for is to post process using an Excel spreadsheet which also involves cutting and pasting to align the tables in rows vs. columns (for summing force values at each POI, LBS exports table data vertically in Excel).
Two examples:  I can't generate a report for Strength I factored girder reactions.  Also, I can't generate a report to find the inflection point due to DC only loads.  Having to create a spreadsheet to sum up load effects due to steel self weight, steel connection plate weight, steel cross frame weight, deck weight, etc., is extremely cumbersome.  Am I just missing something here?
Many thanks for your help!
