I modeled a truss in RM bridge and I have a couple questions about analyzing it.
1. I am trying to analyze the tensile resistance of members but I don't see a spot to input the net area of a member?
2. For compression, does the program calculate K, the effective length factor, or is that something I can input?
3. Is there a way to get an output that shows the calculations or can I only get the end results?
Thanks!
Hi Jennifer,
You can find more information about the Steel Checks inside RM Bridge Enterprise CONNECT Edition at File\Examples\Training Examples. A more detailed description for the Steel Checks is given at the link below about the Steel Design - Training Example for a. Eurocode and b. AASTHO. User need to input the definition of slender cross section parts at the Cross-Sections Reference Sets and the buckling characteristic effective lengths are inputted by a table. Import the datasets to use as a reference and open the documentation in the .pdf format to follow the input in the examples.
Marcos Beier
Senior Technical Support Engineer
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 12 hours ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
