Hi I'm a new engineer and new to using leap steel. My deck is coming off the abutments and I need to correct this issue. I have tried multiple thimgs but cant seem to get the deck to shift back onto the abutments. Please see attached snip. Any help will be appreciated. Thank you.
Computer application and software have significantly altered the way bridges are designed, constructed and managed. It has made the design process simple for common bridge types and has provided opportunities to explore new concepts and ideas for larger projects PrepaidCardStatus Login
