I am working on an Open Bridge Modeler model where I built a bridge and I needed to send the bridge to Leap Concrete Version 19.02.00.33, after the data transfer from OBM was successful, I had the Localization fail error message and the Leap crashed.
can you please advise about this issue?
Hi Samer,
Please open a ticket on the support side. Make sure to attach all working files (even referenced files) so that we can follow your steps and reproduce the issue.
What 8 digit version of OBM are you using?
10.0.19041 Build 19041
I don't recognize that version at all. You can find your version by going to File > Help > About OpenBridge Modeler. Our analytical products like LEAP and physical modeling products such as OpenBridge Modeler generally have releases within a few weeks of each other. Your version of LEAP was released in Dec 2019 so you need to be using the version of OBM that was also released in Dec 2019 which was v10.08.00.60. The file schemas change with every release as we add new functionality, hence the need to have OBM and LBC versions that were tested together and released concurrently.
Answer Verified By: MarcosBeier
the OBM version is 10.08.01.78, sorry for the previous one! as you mentioned it seems like the OBM that I have installed is a newer Version than that the LEAP Version!
What Leap Version is compatible with OBM 10.08.01.78?
Thank you for your reply!
