I am currently using OpenBridge V 10.08.02.45. When placing a custum abutment, the abutment seems to be locked after being placed in the drawing. I tried to change dimensions after it is placed through the info and explorer, some of the dimensions change but the cell does not. Is there a setting that controls this? Thank You! Gerard
Please email me the file and also email me the screenshots showing the locked up screen.
my email is "vinay.mysore@Bentley.com
The issue is how to select the Solid element.
If you click on the Abutment and then modify the properties then the program is not
Changing the model dimensions in the 3D view.
The solution for this issue is to Window select the Abutment and then modify the properties then the program is showing
Changes in the model dimensions in the 3D view.
Answer Verified By: MarcosBeier
