I am modeling my abutment backwall to have the same vertical offset as my backwall depth as pictured below:
And the template cross-section shows up correctly:
Though, when I place my abutment it appears different on the model as shown below:
This is the case for the all the bridges I have modeled thus far. Is this a program error? If so, how can it be fixed?
Modification to the cross section properties of the bridge can be done by clicking on the properties or explorer.
I hope it helps
I am aware of the ability to modify cross section properties by clicking on the properties explorer. The problem is that it is already shown correctly on the cross section properties like mentioned above. The problem is that it's not showing up correctly on the model.
Please email me the file (vinay.mysore@bentley.com) so that i can test this issue.
Will do, thank you.
It's not allowing me to send it to you via email. Is there a way I can send it to you via a cloud service?
