Chamfer for Beams
I am having issues adding chamfer to beams. Bridge is on a major skew of about 50 degrees, and the beams are not skewed with the end bent, therefore, the top flange needs to have a little chamfer. Every time I try to modify the beam to add this through the modeling tab, the beam disappears. Is there a way to do this?
I have attempted putting the beam along the skew and trimming it that way as well as having it non-skewed and attempting to chamfer just the top flange. Any help would be appreciated.
The picture below shows a red line which is where I need to have this beam trimmed down to.
