I am using Leap Bridge Concrete (Superstructure) and am trying to include the weight of additional concrete overlay due to P/S beam camber by modifying the unit weight of concrete under Materials tab. The software is only allowing me to input the unit weight as 200 pcf maximum. Is there any way I can input unit weight higher than that?
Soham:
You can specify a nominal haunch thickness on the Geometry tab, and LEAP will take this load into account automatically for the girders in lieu of modifying the girder unit weight.
Does the nominal haunch thickness account for camber for its dead load?
