I got into a project I had previously finished to make a couple small changes and now the slab load does not appear to be applied. It shows up in the "Loads" window under "Analysis" but the reactions for the slab are basically 0. They are -0.1k at the abutments and 6.6k at the 2 piers. I added a new material type for the deck and changed it in the Deck Slab window, but even if I change it back, it still does not work. Is this a Leap Steel issue due to an update?
Alex ... Sorry to hear you are having this issue. Please file a service ticket and attach your file so the support team can review please. connect.bentley.com
